Case 680E steering cylinders
MeanGene1
Anyone know a source for steering cylinders for a 680E? They are different than the 580s which are easy to find, they have separate hyd lines to each end instead of the tube. Good used would be OK
Looking at the online parts catalogue there are two different type cylinders listed for the 680E,it does not say what the difference is,anyhow I done a search for both and found two of one type on Machinery Trader one in NY and the other in Canada,those are part #G102602,the other # listed is G34886,what is wrong with the cylinders you have,if it's rod damage any decent hydraulic shop will be able to make you up a pair and supply a seal kit and they will be as good as new.
AJ
