removing oil pan on jdeere 450 dozer
Got an issue with the dozer and need the oil pan off
.Turnd it everyway I know and don't see a easy way off
Everything is still together as far as the dozer with the blade on the ground,any help here would be great.thanks
I've worked on quite a few straight 450's,I don't know what the problem would be.Take off the belly pan,then the bolts around the pan and drop it down.I've never worked on anything other than the straight number series so those may be different.
