John Deere 440IC crawler
Tallpine53
New User
Steering issue:
My old crawler runs and works well but.....it won't turn to the left. When pulled back, the left turning lever effectively stops the tractor. The left track pulls with much more power than the right!!
Any ideas will be most appreciated, Thank You
That means that there is no power been transmitted to to the right track,possible causes the right steering clutch is slipping due to adjustment too tight,lever not returning fully,wear of the discs,or oil on the discs,or there could be a mechanical failure like a shaft breaking or a spline letting go,there could also be an issue in the final drive,first check the lever is returning fully,check the adjustment of both the clutch and brake,check the clutch housing for oil,open the drain plugs on the housing bottom drain the moisture and the oil,drain the oil from the final drive on the right side and examine it for metal filings,hoping its only adjustment,
AJ
