Mission Creek
So maybe I?m getting a little lazy here but draining the
hydraulic fluid in my 257B2 is a bit of a hassle. Could a guy
put a quick connect with a steel hose going into barrel, on the
auxiliary port and run it dry to drain the oil? Or is that too risky
to run that low when cold? I?ve seen people run these things
dry because of an unknown hose leak until it wouldn?t move,
add fluid and works fine again. Thanks
