Ok I must be losing my touch (if I ever had it to begin with) I've had many OC3 crawlers in my time that didn't run but this one is really got me Baffled, I recently bought this OC3 in really nice condition sitting in a barn for several years, had an aftermarket carb on it but I also got the original carb. Put a rebuilt mag on it, got good spark, the governor was not working, we took it apart and cleaned it out lubed it up, Got it running finally and governor seems to be working good, when I start to drive it which puts it on a slight pull the governor opens up the throttle from idle but it chokes out and stalls, the choke is open, has no power, changed the plugs, checked compression, all good, checked the plug wires for correct firing order, just has no power, even tried the original carb on it after cleaning it all out. does the same thing. Thought it was starving for fuel but if I squirt gas in the carb when it wants to die out it kills it quicker. Tried moving the mag to time it but it doesn't make any difference. I'm Stumped on this one. Stumped Stumped Stumped
