Let me guess you need the double gear called the hi/lo reverse sliding gear. One side about 21 teeth then a grove for the fork and seems like may be 14 teeth or 9 on the small side? Hector is right the tractor did not share the dozer transmission. Ever used one the Junkers tear down will have the gears you need bad. Not certain but 20 years ago there was someone talking about getting aftermarket ones built. Check with F.P. Smith company in California.
