new water pump 450 john deere dozer
badger450
New User
I ordered a new water pump for my 450 john deere dozer. It came with two small ports about a haft inch in diameter unthreaded. also two small caps and two small nipples that I presume should go into the two holes depending on need. My question is, do I braze the caps or nipples in or just press them in. {they seem a little on the large size to fit into the holes for brazing}
When I got my water pump those fittings were installed I believe. DO not braze them, they are a press fit.
