I've gone off the deep end and am buying a 450 Case Crawler. It hasn't run in a couple of years and has a rebuilt engine with less than a hundred hours on it. I drained almost a gallon of water out of the tank and no diesel so I'll be pulling the bottom inspection cover that will allow me to reach into the tank to see if there is any crud in the tank. Supposedly the tracks would slip off if it turned sharply, but that appears as if the tensioners are stuck and the chains and tracks are acceptable. The starter was giving problems so I'll be pulling it tomorrow to check it out for lube and brush life left. Will also check the hydraulic oil and once it is running I'll be changing all of the lubricants and filters. I found the serial number tag was sandblasted leaving the imagination to what model it really was. The engine has a casting number that states 1972 and that is all that I can find. Does anyone know where there are pictures to determine which year the Crawler is? The price is great and it has a torque converter so it's not a manual transmission like some older dozers are and it has a six-way blade unlike the 450 Case dozers that have the ball-pivot that so many won't loctite the bolts in place and they have to be tightened every day. The excuse they use they use is that the factory recommend not doing that, so the old rentals I've been using have to be tightened daily and that makes no sense. Lousy mechanics don't seem to have much experience. I'd appreciate any and all information concerning this 450 Case Crawler, so I can at least identify it when buying parts.
