Hiddenvalley627
What are the options for rebuilding or replacing the valves that controll the
Need advice on rebuilding or replacing the control valve on 450 C crawler. SN 289711 T. Blade has unacceptable down drift while using. I am aware that the lift cylinders could be a factor but know how to check that. i am pretty sure the bypass is in the lever control valve and need to know the option for either a rebuild or replacement. I especially need to know what shop that could bring any out of tolerance housing or parts in a rebuild back to within tolerance. In past experience replacing parts in an out of tolerance housing etc. wont hold up very long. All advice appreciated.
