JD 450 steering clutch
Hoboy
I am trying to remove the steering clutches from a older dry clutch 450. I know you have to pull the upper pinion shafts for the final drives to get to the innershaft for clutch removal. But what special tool do I need to pull them. I can not get anything to thread in. Is that a JD special thread and do I need a special tool, if so what is the tool number. Any help is appreciated.Thanks
