I have never owned a crawler loader. I am considering buying one for cleaning wooded areas in Illinois. I looked at JD 455G the other day. The machine looks decent and started right up. When I drove it, it did turn to the right very well. I would step on the right turn pedal and nothing would happen. I pumped the pedal a few times and it did turn. I let up and it didn't turn again. The left turn works great. Is this just and adjustment or is something worn out or broken?
The other question is the noise coming from the right track, mostly when backing up. It sounds like the track is too loose and it catches the drive sprocket teeth. You can see it jumping when it makes the noise. Both tracks were sagging more than they should be, by my guess.
The unit has around 4800 hours. I didn't get the year. The owner thought it had around 50% left on the undercarriage. Can anyone help with advise? Thanks
