Massey Furguson MF200 parts
moose4621
New User
I have a MF200 crawler loader which I am in need of parts for.
The final drive output shaft and sprocket retaining nut, and a sprocket with a good centre to which I can weld my existing sprocket ring too.
Unfortunately the existing output shaft and sprocket are unrecoverable.
I live in Australia but it's a small world now and I am having trouble finding parts so international freight is not out of the question.
Can anyone help?
Chris.
[/img]
Hi Chris
Would you happen to have the part numbers of the pieces you need? I may be able to find the parts but I will need the part number to try. I dont
have access to a part book for the 200.
I do have a new armrest for the 200...part number 2707745m91.
I am in Canada by the way.
Wayne
(quoted from post at 23:37:12 03/19/18) Hi Chris
Wayne
Hi Wayne, thanks for your reply.
I only have the part No for the shaft. 975 635 M3.
I changed my seat over to a suspension seat to take the crunch out of my back. :)
Thanks again, Chris
Thanks Hector.
Your name was suggested to me by Jim Stoneman in Victoria, Australia. 8)
I look forward to seeing what you have.
Chris.
I check the sprocket shaft and have no number on and take some dimention 14inchs long and
bottom 1 inch fine tread and 2 inchs for the nut and 36 spleenes with grove on and 36
spleene for the sprocket and have 1 lock nut 5 inchs outsite bolts and bolt 5/8
(quoted from post at 06:28:42 03/21/18) I check the sprocket shaft and have no number on and take some dimention 14inchs long and
Thank you for your time Hector.
I will measure this one today but your description does not sound like what I have.
The sprocket is retained on the shaft by one single large nut and there is no thread on the inboard end of the shaft.
Can you take a photo Hector?
Yes the sproket is retained by a large nut and the inside spleene are for the boulgear and
at the end shaft he has a snap ring for olding the boushing and am ignorant for send
OK, thanks Hector.
That sounds more like what I have.
What price are you wanting for the shaft and large nut?
Can you also organise freight?
Do you know where I could get a sprocket with a good centre?
Thanks again, Chris
