John Deere 350 Dozer B or C ?
Viking
New User
I have a John Deere 350 Dozer old Iron just rebuild the engine is their anyone that can tell me the year model of this dozer by the serial number ?
Serial Number SNM 43TF033503
Thank you
Viking Phillips
according to JDEM's post under Frosty11 (a few posts under yours) its a 1967 unless you have left out a number. That would make it a straight 350, as there is no 350A designation. I thought by the looks of it it would be 1960's with a homemade cab. My '69 350 had a factory cab.
I was thinking after I made this post the serial numbers came off the engine not the frame.
Thank You
Viking
Just look under the seat. If the two steering levers hook to two control valve spools in the middle, it is a wet-clutch machine.
Also - all wet-clutch machines that I am aware of came with NO reverse in the gear transmission. Dry clutch machines usually do have a gear-reverse. That is because the hydraulic power-shift reverser was only an option on dry-clutch machines. On wet-clutch machines - it has to be there since the reverser powers the steering clutches.
I looked under the seat and the two steering levers are both separate.no control value in the middle.
My 350 Dozer has reverse on the transmission like a regular stick shift.
My 350 has reverse in the transmission no reverser. Is your 350 wet clutches or dry ?
Thank You
Viking
Then it is a dry clutch machine and has to be a 350B or older. 350C has to have a hydraulic reverser. In fact, as I recall near all 350Bs came with a reverser too except the early ones. So if it has no reverser, it has to be an early 350B or a plain 350.
"69's were still dry clutches. Serial number may be an a tag under the front of the seat.
I found serial numbers under the seat on the frame T24859 and T24868 one number above the other.
I am looking for both top rollers for this machine would you know who might have them ?
Thank you
Viking
