TractorLinks.com
John Deere 350 Dozer B or C ?
viking
03-13-2018 19:22:12
I have a John Deere 350 Dozer old Iron just rebuild the engine is their anyone that can tell me the year model of this dozer by the serial number ?
Serial Number SNM 43TF033503
Thank you
Viking Phillips
DrLoch
03-17-2018 06:50:30
 Re: John Deere 350 Dozer B or C ? in reply to viking, 03-13-2018 19:22:12
Is that correct or is it Nortrax ?[/i]
2x4
03-18-2018 01:45:05
 Re: John Deere 350 Dozer B or C ? in reply to DrLoch, 03-17-2018 06:50:30
believe you are correct.
JDEM
03-14-2018 05:08:43
350B has dry steering clutches. 350C has wet steering clutches. BIG diference.
viking
03-15-2018 04:08:20
 Re: John Deere 350 Dozer B or C ? in reply to JDEM, 03-14-2018 05:08:43
How would I determine the difference between Dry Clutch or Wet ?
Thank You
Viking
JDEM
03-15-2018 07:56:20
 Re: John Deere 350 Dozer B or C ? in reply to viking, 03-15-2018 04:08:20
Just look under the seat. If the two steering levers hook to two control valve spools in the middle, it is a wet-clutch machine.
Also - all wet-clutch machines that I am aware of came with NO reverse in the gear transmission. Dry clutch machines usually do have a gear-reverse. That is because the hydraulic power-shift reverser was only an option on dry-clutch machines. On wet-clutch machines - it has to be there since the reverser powers the steering clutches.
viking
03-15-2018 17:57:37
 Re: John Deere 350 Dozer B or C ? in reply to JDEM, 03-15-2018 07:56:20
My 350 has reverse. No reverser.
viking
03-15-2018 17:50:52
I looked under the seat and the two steering levers are both separate.no control value in the middle. My 350 Dozer has reverse on the transmission like a regular stick shift.
JDEM
03-15-2018 20:04:18
 Re: John Deere 350 Dozer B or C ? in reply to viking, 03-15-2018 17:50:52
Then it is a dry clutch machine and has to be a 350B or older. 350C has to have a hydraulic reverser. In fact, as I recall near all 350Bs came with a reverser too except the early ones. So if it has no reverser, it has to be an early 350B or a plain 350.
viking
03-16-2018 03:35:06
 Re: John Deere 350 Dozer B or C ? in reply to JDEM, 03-15-2018 20:04:18
Thank you
Viking Phillips
2x4
03-13-2018 23:28:14
according to JDEM's post under Frosty11 (a few posts under yours) its a 1967 unless you have left out a number. That would make it a straight 350, as there is no 350A designation. I thought by the looks of it it would be 1960's with a homemade cab. My '69 350 had a factory cab.
viking
03-15-2018 17:55:01
 Re: John Deere 350 Dozer B or C ? in reply to 2x4, 03-13-2018 23:28:14
My 350 has reverse in the transmission no reverser. Is your 350 wet clutches or dry ?
Thank You
Viking
2x4
03-16-2018 00:52:30
 Re: John Deere 350 Dozer B or C ? in reply to viking, 03-15-2018 17:55:01
"69's were still dry clutches. Serial number may be an a tag under the front of the seat.
viking
03-15-2018 04:05:29
I was thinking after I made this post the serial numbers came off the engine not the frame.
Thank You
Viking
viking
03-16-2018 17:01:09
 Re: John Deere 350 Dozer B or C ? in reply to viking, 03-15-2018 04:05:29
I found serial numbers under the seat on the frame T24859 and T24868 one number above the other.
I am looking for both top rollers for this machine would you know who might have them ?
Thank you
Viking
2x4
03-17-2018 00:47:17
 Re: John Deere 350 Dozer B or C ? in reply to viking, 03-16-2018 17:01:09
Nortrac
viking
03-17-2018 05:16:35
 Re: John Deere 350 Dozer B or C ? in reply to 2x4, 03-17-2018 00:47:17
Thank You Sir
Viking
