I have one with a rear mounted hyd unit that stops when you pop the clutch, how hard would it be to find a front mount engine drive setup and
what would it cost. My rear pump leaks oil into the differential anyone know what might be causing the seal keep leaking my dad changed it
several times and would still leak I was never there so I don' t know if something is damaged or not had anyone worked on one of rear pumps
