TractorLinks.com
Re: Case 450 dozer brakes
AJ.
02-08-2018 02:15:33
You will probably need to remove the brake housing,it may be the linkage has come undone inside,or oil has leaked in,the spline on the actuator shaft could be stripped,once the slave cylinder is working the trouble is inside the housing.
AJ
rpatterson
03-04-2018 12:08:42
 Re: Case 450 dozer brakes in reply to AJ., 02-08-2018 02:15:33
I've been reading the post and decided to repair my Case 450 brakes too. Removing the housings and cleaning things up. Appears the seal has been leaking fuild into the brake housing for sometime, guessing the shaft seals are bad. Any advice on removing the brake mounting plate?? My Case manual doesn't contain any info and can't fiqure it out.
