Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Case 450 dozer brakes
wally b
02-07-2018 14:34:36
Case 450 dozer left brake not working and I don't think it has worked for a while. I got this dozer recently. The hydraulic part of the braking system works and so does the slave cylinder. It de-clutches the drive transmission but the left brake wont engage even with the adjusting screw fully tightened. I think the problem is in the braking housing within the brake shoe mechanism. Any thoughts or advice on taking apart? Any thoughts on other possibilities or common causes of them not working?
I cnat tell from the parts diagram how the brake actually slows the track--it does not show a shaft that it works on.
Case Nutty 1660
02-11-2018 07:15:55
 Re: Case 450 dozer brakes in reply to wally b, 02-07-2018 14:34:36
If I might add to AJ's comment,, if it has stuck at some point and gotten hot it will take the temper out of the springs and they will be "long" and not re-track the way they need to, this also most times takes the chrome off the actuation balls so they need replaced as well, I have had some luck if they are not oil soaked to buff the glaze off so they "grab" well again cnt
AJ.
02-08-2018 02:15:33
You will probably need to remove the brake housing,it may be the linkage has come undone inside,or oil has leaked in,the spline on the actuator shaft could be stripped,once the slave cylinder is working the trouble is inside the housing.
AJ
