Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
JD 450B crawler fuel problem
sms
02-06-2018 13:30:32
Machine was running working fine but I found fuel was leaking from the primary filter, changed the filter, now cannot get fuel from bleeders. I loosened the fitting at the casting and get good fuel flow there but cannot seem to fill the filters and get fuel from the bleeders. This is using the manual pump of course. Tank is full valve is on as I said I have fuel to canister. Old filter was Wix 33166 new is Napa 3166. Any ideas?
Dieseltech
02-06-2018 16:15:08
 Re: JD 450B crawler fuel problem in reply to sms, 02-06-2018 13:30:32
Did you make the common mistake of putting an O ring in the filter top outer groove? That's the filter inlet, it must be open..
sms
02-06-2018 17:16:01
 Re: JD 450B crawler fuel problem in reply to Dieseltech, 02-06-2018 16:15:08
I did, I was quite sure there was one in the old one. Oh well back to the drawing board. Thanks
Dieseltech
02-06-2018 17:25:52
 Re: JD 450B crawler fuel problem in reply to sms, 02-06-2018 17:16:01
I've lost count how many times I've seen that happen, at least nothing is broke and will be an easy fix.
welding man
02-06-2018 17:32:12
 Re: JD 450B crawler fuel problem in reply to Dieseltech, 02-06-2018 17:25:52
So have I Rich. When is WIX /NAPA going to redesign that stupid filter?
Dieseltech
02-06-2018 17:42:31
 Re: JD 450B crawler fuel problem in reply to welding man, 02-06-2018 17:32:12
Redesign? Probably never. Maybe they could at least stamp a warning on top, DO NOT BLOCK OUTER TOP FUEL INLET GROOVE! I'm not holding my breath though...
