Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Shop time steering clutches 450C
Hiddenvalley627
02-01-2018 06:20:44
Could anyone give me the Shop time for a Steering clutch R&R on a 450 C JD?
Thanks you in advance?
JDEM
02-03-2018 07:01:01
 Re: Shop time steering clutches 450C in reply to Hiddenvalley627, 02-01-2018 06:20:44
We had to use flat-rate at our Deere dealership for warranty work. Otherwise - never. As the other poster mentioned - broken and stripped hardware is a huge issue. Especially with a 350C. Not as bad with a 450C since the final drives do not have to come off. In a best-case, I would expect 10-12 hours labor to do both sides.
2x4
02-02-2018 23:34:14
saw one estimate of $6000.
MSM
02-02-2018 15:14:35
I don't really think there is a set shop time to R&R steering clutches except for warranty work when the machine was new. On a used machine there are too many variables(rusted,or broken bolts,tracks that won't easily come apart,bent linkages,previous owners patch jobs, worn or damaged bearing quills,etc. It's one of those things that if it takes 6 hours,or if it takes 15 hours you are going to pay shop labor rate for the repair.
welding man
02-03-2018 05:47:18
 Re: Shop time steering clutches 450C in reply to MSM, 02-02-2018 15:14:35
You are correct on flat rate. Common sense has to prevail. We use flat rate manuals as a guide.There are just too many variables that come into play. We try to be fair to the customer,but we are not going to to do the job for free either. I had an old friend that said you can never loose money pricing your own labor. You may not make what you want per hour but you still won't be working for nothing. If you are paying an employee that is a different story.
