Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Cat D5G sticky valve
Mission Creek
01-29-2018 08:38:31
Got a D5G from an auction not too long ago, everything seems to work fine except the twisting action on the right blade joystick T handle. Sticky is an understatement, need both hands to twist it left and can barely get it right with one hand. This would control the blade angle. The blade moves perfectly with the joystick once you can get it turned. Everything else on stick is smooth. Any general ideas before I blindly tear into it? Thanks
texas cowboy
01-29-2018 18:47:56
 Re: Cat D5G sticky valve in reply to Mission Creek, 01-29-2018 08:38:31
Try spraying it as mentioned but on my 4G I had to take it apart and replace a bearing. You can take the linkages off and work the valves to make sure the problem is in the joystick. It's been a couple of years ago but I don't remember it being too bad of a job. Tony
jm.
01-29-2018 15:31:55
Open the right battery door, take something like PB Blaster and spray your linkage,, MOST likely not in the valve but in the linkage there under the arm rest.
