Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Re: John Deere 310E TLB Accessory Relay
jsborn
01-26-2018 07:25:39
When we got the new solenoid it came from JD and was suppose to be the right one. They did have a time finding it so I am going to look at my sales ticket and see if indeed they sold me the right part . I understand what your saying about cont. vs interm. that is why I am looking for the answers to my questions above.
JDEM
01-26-2018 14:03:33
 Re: John Deere 310E TLB Accessory Relay in reply to jsborn, 01-26-2018 07:25:39
The only difference between a continuous-duty relay and an intermittent duty relay is spring pressure and amp-draw. A continuous-duty relay has very low spring pressure to hold the contacts open and subsequently,can use a weaker electro-magnet to engage. A continuous duty relay will draw less then one-amps @ 12 volts. Also not as reliable as an intermittent-duty due to the lower pressure holding the contacts closed. That is - unless you buy a pricey one with something better then copper contacts (like silver). A continuous-duty relay can draw 2-8 amps to engage. I have seen them used to replace continuous-
duty relays and have not personally seen one fail. Just run a lot hotter and waste power.
If not sure what you have - just check the amps it takes to engage. Should be 6/10ths of one amp and maybe less.
