TractorLinks.com
Re: 336 case, engine block
AJ.
01-24-2018 04:23:26
You must have the compressor oil lines connected,you cannot block them off otherwise the compressor will seize up,that fitting you need is an 90° elbow,one end threaded 1/8npt,the other end tail,it's low pressure with a clip,the Case part #A27489,you might get a fitting at a plumbers shop.you are nearly there keep at it.
AJ
Trak
01-29-2018 15:42:21
 Re: 336 case, engine block in reply to AJ., 01-24-2018 04:23:26
was about to give on that one,, I got it out and put a ninety in,.. thanx
