jcb 1400b backhoe
ricky jcb
New User
Hey,I recently purchased a 1988 jcb 1400b backhoe.I can operate machine about 2 to 3 hours and it will come to a slow idle then engine will shut off.I have changed all the filters including fuel and installed a manual temp. gauge.I thought overheating might be problem.Temp. max.only about 180.Could it be an electrical issue?
Is the fuel tank vent plugged? Loosen fuel cap and try it again. Yes I have had it happen on a diesel even with a lift pump.
Perkins 4.236,there is a washable gauze in the feed pump,undo the screw in the center of the dome and remove the gauze,clean it and the body of the pump and see how you fare.
AJ
