joefleming
New User
Just purchased machine used Used machine for 2 days and all was fine. Next day shuttle shift started intermittently working Moved it down to where I could troubleshoot problem at my garage and I noticed the Powersteering was intermittently working along with it not moving
Finally got it to an area to look at but have not figured it out. When I checked trans fluid it was overfull by about 4 gallon. Changed out fluid but still nothing. Is it possible that it could be Th steering pump? The power steering pump does draw fluid from the trans case I'm sure it could be a thousand different things but losing the steering at same time as losing forward/reverse movement is making me look in this direction.
