TractorLinks.com
Re: mitsubishi BD2G Dozer
Tracy Brown
11-14-2017 14:15:37
Well, I bit the bullet today. Ordered new chains, weld on sprocket rings, and new hardware set to re-mount the pads.
RBoots
11-14-2017 20:07:54
 Re: mitsubishi BD2G Dozer in reply to Tracy Brown, 11-14-2017 14:15:37
Take your new sprocket rims and line them up on the old sprockets. Then either clamp or tack weld the new sprocket to the old one and use it for a template to cut off the old one. Make sure you make a hash mark across both pieces to line it back up when you go to weld it back on. Then do it like a truck rim with clamps on it, tack one side, set a block of wood next to that spot, then turn it slowly and tack the opposite side, work your way around it. Pretty easy job, good luck!
