JD 450C - block heater location
We sold a lot of 350cs and 450Cs new. We added block heaters when requested by the buyer and they were circulating tank-heaters. Connected between the block-drain and the thermostat housing. As I recall, 450Cs came from the factory already drilled and tapped for the hookup on the thermostat housing. Older machines we had to drill and tap ourselves.
152 three-cylinder in the photo. Four cylinder 180, 202, 239, etc. done the same way.
