I've got a Dresser 412B that I bought to use around my small farm and it has developed a problem. A hydraulic hose was leaking so I parked it until I had time to work on it and it sat for about 2 months before I had time to look at it. It wouldn't start so I replaced the batteries (tested bad) and even took the starter off to have it checked but it was good. I'm wondering if I have a head gasket leaking water on top of a piston causing a hydro lock? Can I remove the injectors to check for this? I've never had to make a repair like this so I'm in unfamiliar territory. Any input/advice is welcome.
Thanks,
Scott
Thanks,
Scott
