Case1840BC
New User
Hello everyone, I could really use advice how to proceed with oil dripping out from a 3/4" threaded hole in the bottom of flywheel housing. First thought was it is the main engine seal but then I realized it is the hydraulic oil because it is very clean compared to the diesel engine oil. If I got it right the oil from the tandem drive pump must be leaking around the splined shaft that slides into the splined coupler inside the flywheel housing. I searched the Case forum and so far I did not find anyone having similar problem so I am at loss what to do or how to fix it. The oil starts dripping as soon as the engine starts. I used an inspection mirror and saw few drops falling down then followed by a short trickle, then nothing for a second, then again drops, trickle and so on. The skid steer moves no problem but going up hill it leaves an oily track behind and I have to keep refilling the hydraulic oil in the main tank. Did anyone had the same or similar problem and could share some ideas what to do? Thank you. Case 1840BC
