JD 550G wont go in first gear forward
2x4
move selector to 1st forward & it doesn't want to move. 2nd & all the rest forward & backward work. 1st worked good earlier this week. Move it from 2nd down to 1st still wont go. Mechanic says strainer may be blocked from long-term sitting, Usually only run it every 3 to 6 mos. Is their an additive I can put in to loosen the valve? Hate to change 27 gallons if I don't have to.
Does 1sr REVERSE work.. I think you have blown a clutch pack. Strainer or filter would affect all gears the same.
