TractorLinks.com
Re: Case 1740 uniloader clutches
Chris in SK
10-12-2017 14:27:13
Roy, I just had a look at my 1740 and at the parts book. If you look at the parts diagrams on CNH or Messicks web sites you can see the clutches. It looks like behind the two big nuts on the side covers (one for each clutch) , there is a seal, then a thrust bearing and some shims, and then a larger ring called the 'adjusting nut' in the parts book. Looks like it may need a spanner or punch or special tool. It looks like the Formsprag clutch has two set screws that lock this adjuster nut and the Stearns clutch has one locking screw. Not sure if you have to remove the side covers to access this adjuster nut or not. Hopefully mEL from the Case page or one of the other guys that know these machines will confirm.
IA Roy
10-12-2017 20:23:26
 Re: Case 1740 uniloader clutches in reply to Chris in SK, 10-12-2017 14:27:13
My son feels lucky. He found a broken drive chain on the side that quit. It was the first stage reduction #40 chain. He has downloaded the parts manual. Thanks for the replies
