Massey 60 backhoe
Davidj
Hello all. I have a massive hydraulic oil leak. I think it's one of the cooler lines. It's somewhere around the starter or slightly rearward of it. I'm wondering if I need to remove the fuel tank to get in there, or do the lines run the length of the frame rail... Hard to tell exactly where and what is leaking as it's hidden from plain view. Any and all help most appreciated. Thanks
Update.... Everything was covered in a thick layer of grime so I laid the pressure washer to it. Found the culprit and after moving a few other hoses out of the way and removing a couple of small floor panels, I was able to change out the small hose. About 25 bucks at the local hydraulic shop. Would've been an easier repair with a couple more elbows on each arm. Haha. Worst part was losing a couple of pails of oil at $55 apiece. Enjoy the day.
