kelly bckhoe
I recently purchased a backhoe attatchement that clamps on the back of a tractor with solid bars not 3pth. im told it is a Kelly backhoe. I need parts to be specific spools for the 6 function valve body. Kelly has no parts for such a valve. the valve is made by hydreco they also have nothing, any ideas where to source such a valve or parts new or used ?
Valve spools are NOT replaceable as such on service parts for valves are seals. What is the problem with you valve? External leaking or hard working?
(quoted from post at 03:29:10 10/09/17) Valve spools are NOT replaceable as such on service parts for valves are seals. What is the problem with you valve? External leaking or hard working?
3 spools out of 6 are broken
Places like surplus supply or Northern sell them and your probably better off buying a whole new set of valves instead of trying to fix what you have since most are not repairable
