jayjones56
New User
This message is a reply to an archived post by IowaJohn on October 21, 2012 at 20:28:05.
The original subject was "Re: bobcat 610".
A little History First:
I worked for Rental Tools and Equipment Co years ago as a driver and fix it guy. Early 70's
The Melrow Bobcat was what they rented back then and I used to work on basic repairs for them.
Bought one recently and have done the following:
Bought new tires and rims, (old ones were shot and mismatched rims)
New tires rubbed the side of the bobcat
Bought Wheel Extensions to get the tires off the side of the bobcat
New Battery
New fuel filter
Flushed fuel tank and added water removal and fuel cleaner in tank prior to flushing
New full fuel (high test)
All front and rear clutches replaced
brother in law removed old trans fluid and put in new, but now it is milky white, water crud still, plan to flush trans oil system and add New transmission oil
brother in law also rebuilt Carb with kit
Head gaskets were leaking so both have been replaced and torqued properly 22 ft pounds
Replaced fuel line hoses and put on new fuel filter
New points, condenser and plugs (ordered Electronic ignition to install when it arrives)
New starter bendix
Pressure washed it really well, cleaned out debris in heads when I replaced head gaskets (they were leaking badly but still would start and run)
Issues:
It ran at high speed with no load on it, as soon as I tried to drive it or use hydraulics it would die down and stall out if I did not let off.
It would run at idle as well.
Now it won't start,
One comment I read said something about nose down and the carb floods, I have the bucket turned way down to have the front wheels off the ground (poosible flooding)
Checked for spark and not seeing any
Also,
THe hydraulic clutch on the main engine shaft does not seem to work, can it be changed to single speed pulley?
New Battery
New fuel filter
New starter bendix
Issues:
Now it won't start,
Also,
