steering clutch drain plug location on john Deere 455E track loader I have drained the oil from the transmission and now the manual tells me to drain 3.5 gallons from each steering clutch. It says under the rear of the machine. I see nothing under the rear of the machine that looks anything like the picture. I see a drain plug at the very bottom of the final drive and a plug half way up the final drive front and back. A larger plug is at the very top of the final drive which I figure is where I pour the oil in until it comes out the holes half way up the final drive when changing the final drive oil. I see an even larger plug over top of the final drive and of set(3/4 inch socket set extension to remove it) I assume it is the fill for the steering clutch, but can not locate a drain plug.
Thanks for any help
Thanks for any help
