clutch adjustment on 59 Case Industrial backhoe
59casey
Can anyone help me out on wanting to adjust the clutch on a 59 Case Industrial 420 B H backhoe? I am in the process of ordering the operator's manual but don't have a service one. Photos would be appreciated.
This is a direct drive with a conventional clutch? if so on the left side of the torque tube you will find a rod from a lever going into the bellhosing to underneath the clutch pedal,loosen the jam nut at the clevis at the pedal end tighten or loosen the adjustment by turning the rod.
AJ
pics of the linkage on a gas engine model
