Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Caterpillar 933 11A
Joker123
09-09-2017 05:42:01
Hi everyone one , am in need of some help! The track came off my cat. After I put it back on . That side don't want to drive any more. Also the brake doesn't work any more on that side. I think some thing is broken from the brake down to the final drive. But where do I start looking?
Maybe one of your guys can point me in the right direction.
AJ.
09-09-2017 14:09:37
 Re: Caterpillar 933 11A in reply to Joker123, 09-09-2017 05:42:01
Either the spline has sheared in the brake drum or the final drive has stripped some teeth,drain the oil from the final drive housing and check it for metal.
AJ
hector gemme
09-09-2017 10:10:50
You could check the brake linkage and removed the small cover for the adjustement brake and maybe the pinion spleene are stripp or bevelgear shaft stripp in stering cluch drum
hector gemme
09-10-2017 04:08:09
 Re: Caterpillar 933 11A in reply to hector gemme, 09-09-2017 10:10:50
The small cover near the brake pedal is attached on final drive housing
Joker123
09-09-2017 17:56:40
You are talking about the rectangle cover underneath the crawler?
Joker123
09-19-2017 17:07:25
 Re: Caterpillar 933 11A in reply to Joker123, 09-09-2017 17:56:40
Hi guys I have taking the final drive apart and found a broken Pinon shaft(part #2F1175 )
Any of you guys would know where I can find a used Pinon shaft?
Thanks
Joker123
09-19-2017 17:10:42
 Re: Caterpillar 933 11A in reply to Joker123, 09-19-2017 17:07:25
Am trying to upload a picture
