780 case backhoe 336bd-t oil pump
trak
the balance gears on the one I have, only have one timing mark on each one, you would think one gear would have two marks, or you will be a tooth off one way or the other. had my eye on one, but screwed around too long, it sold. think w14, 870 case tractor are the same. wow, just can't seem to win with this thing, guy helping me on it seems to think he can rebuil the old one, its so rough, but too even mention buying one seems to get a (are you nuts) reply,,, I think he's the crazy one.
By the rule of thumb one mark is at the bottom of the vee between the teeth and the other at the bottom of a tooth,when put together the marks are opposite each other,when you are not sure taking those things apart why not put your own mark on them to avoid confusion when putting them together.
AJ
