Advice please
Tightened up my track on a case 450 dozer with the grease gun. Lost most tension after about 2-3 hrs of moderate load work--the track is about to jump the
sprocket. I refilled the track tensioner with grease and al ot of grease is coming out under the covering at the back of the tensioning rod as if there is a rear seal
leak. The grease is coming between the front of the cover over the track spring. Looks like I need to remove this to replace the seal.
Any thoughts or instruction on how to easily do this?
Thanks
Thanks
