Help identify international back hoe
I can't figure out what it is. It's a 4 cylinder gas.
All I see is the front of a tractor and the front of a loader. If you want to ID the backhoe, post some photos of it. Many if
not most IH backhoes have an odd-ball rack and pinion swing system. Like IH models 3120 or 3121. I have a model 3414 loader-
hoe here which is basically a B-414 farm tractor with a 3121 backhoe on it.
the loader is a Great Bend built loader "GB" they made them for Case as well back then,, the backhoe unit sure looks IH to me with those controls
cnt
I have a 340 international back hoe. has know pto so I do think it came out as a back hoe. you tires /rims are the same. hood id close but I suspect your hood might have been replaced. if you can put a photo of your dash I can check to see if its like mine. my back hoe actually has a chain that swings the boom right or left driven by hyd rams. its a 1961 but your hoe is different than mine.
(quoted from post at 11:44:51 07/28/17) I have a 340 international back hoe. has know pto so I do think it came out as a back hoe. you tires /rims are the same. hood id close but I suspect your hood might have been replaced. if you can put a photo of your dash I can check to see if its like mine. my back hoe actually has a chain that swings the boom right or left driven by hyd rams. its a 1961 but your hoe is different than mine.
It'll be a couple days till I can get to the hoe again to take a pic.
