[email protected]
New User
I am new to this cat and had an hour of light brush work when all of a sudden the right steering brake stopped working altogether. Shortly after, I lost all power to the tracks. Upon checking fluids, the transmission was almost empty. Refilled and power to the tracks was back but no change to the steering .....I assumed the two would have been related. Since then, I've tightened the 9/16 hex in and backed off a turn, the pedal now has very little travel till it hits resistance but still no brake. I later found out that the "drain bolt" on the underside was removed and drained water etc out and was left out. I believe this is a 2 purpose bolt, a drain but more importantly, a brake band under support to keep the brake band from resting on the rotating p[arts and wearing out. Can anyone help? I was planning on removing top plate and checking for throw out actuation next.....Thanks for any help
