Case 480B ck
74runner
New User
I purchased a 480b Ck backhoe from the neighbor knowing that it needed some work. Split motor from tractor to replace clutch, manual shuttle shift wouldn't stay in forward removed shifter cover and found that the forward gear and sync. assy. had major problems. Purchased a manual, index says section 92 to split the torque tube from the final drive. There isn't any section 92 in the manual does anyone have or know where I could purchase that section
have you looked through every page? I have seen many of them put in the wrong spot I should have what you need in a 580B sm as well if you dont have it,, it might be a while till Zi can scan it though as I am getting ready to combine now
cnt
