mitsubishi steering
pruit
New User
I
have a mitsubishi BD2F dozer,the right
track doesn't seem to want to drive,
when it gets any resistance, and it
won't steer to the left. the previous
owner said that he replaced the right
clutches. Any help would be great.
thanks.
Clearly there is no drive going to that side,either the clutch is slipping of there is something broke in the drive train,see the clutch is adjusted correctly,put a pry bar in the sprocket and check for play,drain the final drive oil for that side and check for metal,it is best to establish what's wrong before tearing things down.
AJ
Hey AJ, I got back to working on the mitsubishi dozer BD2F, the clutches on the right side are gone, do you know where I can get them? And I think I will do the brake also. It's not warn to bad, but it's got a couple cracks in it, and looks like about an inch is broken out on the one end can they be re lined? And where. Thanks Pruit
Sorry I'm in the UK,was the Cat dealers that done the parts here but I would Google it and see if there is any aftermarket supplier.
AJ
Question for any one that can help. I'm looking for the seal on the pinion shaft for a mitsubishi BD2F for the final drive. I have the parts book with the number and I gave it to Saddlers and they couldn't find any thing 58833-12600 is the number. Thanks
Take the seal to a bearing supply shop and unless it is special they should be able to match it for you.
AJ
