ratskinner
I have a case 1835B skid steer with a 188D engine .The other day is started to run bad and smoke(white smoke) so bad the mechine would disappear in a cloud of smoke.
well everyone i talk too said it was the injector pump .So i had it rebuilt and put new injectors in it .
Had a hell of a time getting it all timed right .Well i got it all back to gather and running .
Now the problem is it running real rich (white smoke ) and it runs great for 20mins and the it starts to lose power and quiets.
I am wondering if i have done something wrong when timing. On the fly wheel is some lines and the #10 stamped in to it I brought it to the #10 and then moved it to the 8deg mark lined up the cam mark with arrow and the injector pump the other side of the arrow and the lines in the window on the injector pump are lined up .The injector pump is move away from the motor as far as it goes If i move it in toward the motor it will start to run real bad and smoke real real bad .So whats wrong
I dont know if this matters before all this started the water pump went out and the motor over heated ,it know has a new water pump.
