Terratrac gt-34
ffreeb
I'm trying to find a sprocket and axle for this and having no luck. I've been told that it is the same as a 310 Case. Does anyone know?
what is the number stamped on your sprocket. I have a sprocket and shaft from a case 310 crawler. your shaft you need to measure, count the number of slides. you can email me at b r s h s g @ y a hoo. com
Check the track pitch on the GT , I think it is different
than 310 . I don't have the specs for the GT , but 310 is
23.5 new and 24. over 4 pins.
Send me an email , I have converted several from splines
to taper with key.
george
