glennster
switched the connectors around like you suggested. it now throws code 32-40 lift handle not calibrated. i tried several times to run the calibration where you tilt both controls inward full, then key on, the press operate button. the solenoids are supposed to activate but do not run thru the calibration cycle. i would of thought the right control now hooked to the lift solenoid, and the left control now hooked to the right curl solenoid should have raised the bucket with the right control. the left control now plugged to the curl solenoid should have curled the bucket if the solenoid was good. does it look like the curl solenoid or valve is bad?? i did unplug the battery for an hour to try and clear the computer, but it did not clear the codes.
