Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
780 case backhoe engine
Trak
06-18-2017 12:42:01
336 cummins, wondering if the crankshaft gear that runs the oil pump can be replaced, its toast. It's welded on with two inch welds. or where one might purchase the gear if its possible to replace. thanx
AJ.
06-19-2017 11:16:36
 Re: 780 case backhoe engine in reply to Trak, 06-18-2017 12:42:01
The engine is a Case 336BD or 336BDT if its a turbo not a Cummins,the gear you are looking for goes on the middle of the crank to drive the balance shaft oil pump type,that gear is part of the crank and is not sold separate,you may be able to get a used one from someone with a junk crank,as I never changed that gear or know what it involves regarding alignment and balance,there was a front driven oil pump setup but I again cant remember will it fit to that block.
AJ
Trak
06-18-2017 12:43:01
also will need an oil pump
