I need to pull the injector pump on my crawler. The manual says,"Bar the engine in direction of rotation until the timing line on the governor...registers with the timing line on the cam."
So, I am assuming the term "Bar" means to turn the engine but how do you turn it? On a car, I get a socket on the harmonic balancer nut to turn the engine, but the JD doesn't seem to have a good place to get a hold of anything. Also, it seems like it takes two people even if I could figure out how to turn the engine because you need to see the index mark to know when to stop.
Any tips would be appreciated. Thank you.
