Having my injector pump rebuilt and they told me I should clean out the return line as it could be clogged up by pieces from the damaged pump.
Can I use a compressor to blow air into the cap at the front end of the return line that runs to each cylinder and then to the pump and gas tank? Would that also blow air down each line toward the pump? Would it be bad for the injectors?
Thanks
Thanks
