MF 200 Dozer
ms0115
New User
I have a MF 200 dozer that came to my shop. The symptoms are: the clutch pedal is loose and there is no resistance. Is this normal when the machine is not running since it is a hydro-stat? With the machine running , clutch out you can shift the shuttle forward and backwards with no effect. Changed the filter, added some oil, cracked the pressure line from the pump. Oil ran slow and had air in it. I am ordering a shop manual, but are there any ideas where to go from here?
I will call tomorrow. What time zone are you in (eastern, central, mountain or pacific)?
Thanks for working with me.
