Billturner
New User
I started using the 350D that I posted earlier about the winch problem, got it fixed and is 100%. I was working on my first old stump to be dug out and when I turned hard left in reverse, moving quite a bit of dirt with the track, the right track popped, sounded like it slipped a tooth on the sprocket. It only does that on that side and when pushing forward full throttle all the way to almost a stall no slip. It only does it when backing up and only to the left. It did it several times. I did check the track tension and the sag in the track from the sprocket to the top track roller is under 1". It looks like I could tighten the track a little more but not much. I did look at the sprocket teeth and that one does seem to be rounded rather then square on the end of the tooth. The thing that ran through my mind was finals, could there be a problem there? Seems like it would happen in forward also. This machine has an honest 3500 hours and has been taken care of well.
